Service Menu for the Sony kv32fq80
Discussion in 'General TV Discussions Forum' started by mmm, Feb 6, 2003.
  1. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    been looking around on threads and other forums to find out if there is a "service menu" on the sony KV32FQ80 ?
    I am guessing there isnt much info yet on this model, but any ideas :confused:
    fank q
    m :cool:
  2. anthonyb
    anthonyb
    I've just tried it on my FQ80 and it's the same process as the FQ75.
    Good luck and heed the advice you see on this forum - record every setting BEFORE you muck around with it and don't use the reset / restore option!!!
    Anthony..
  3. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    Cheers mate, shall try it when I get the TV back from the repair shop...:(
    regards
    mmm
