service menu for phillips 32pw6518
Discussion in 'General TV Discussions Forum' started by gbmitie, Apr 3, 2005.
  1. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    republic of ireland now
    +62
    Can anyone tell me how to access service menu on my 32pw6518? I need to know just in case. I am sure pic is sloped inwards at bottom so may be able to fix it.
    I just hope HD sets are nice and simple!!!
    gbmitie
  2. devilhimselfff
    devilhimselfff
    I have a 29PT9421 and I have the same (almost) trouble but unfortunately there is no fix in the service menu, but do try your luck. But before you change anything do write down the original settings.
    CODE IS 0 6 2 5 9 6 [i+]
    Dont worry about the channel changes, Hope it works on your Tele too.
    Please do let me know if there is a fix.
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    +62
    thanks for reply but erm how do I enter that code? I assume it is via the remote but just want to be sure!
    gbmitie
  4. devilhimselfff
    devilhimselfff
    Hi there
    Well buddy yeah you are suppsed to enter the code by Remote, but I think you shouldnt as if you mess the setting up it would be IRREVERSIBLE and might DAMAGE YOUR TV and the warranty would be off. SO MY OPINION if you wanna do it then first write down the ORIGINAL settings and then mess around with it. OR JUST DONT DO IT.
    :nono:
  5. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    +62
    thanks, I know what u mean. I will have a brief look and tread carefully, if I mess it up I will be dead meat.
    gbmitie
