Service Menu Code for 32PW8620/12
J
JunkieXL
Hello everyone :)
i have tried the various codes floating around here, none of'em workin.
does some1 know a valid code (and usability) for this particular set ?
thanks
junkie
C
Cynthia 7
Hi Junkie XL,
Since I have a Philips 36PW9618 myself I copied down some service codes that someone had once listed on this forum. I've never had necessity to go into the service menu so I can't say if they work. Do take great care as apparently you can really muck up your set and it then requires a dealer to put it right.
These are the codes: 062596 and then the i button (also known as OSD or STATUS button). Message "dealer" should appear. Other codes are: 0162596 0362596 0462596 0762596 0862596.
I copied this down from a member of this forum, hagbard, from 15.9.2003. The tv in question then was the 32PW9534. I think the PW relates to the chassis so it should work for you too. Make a note of your previous settings whatever you do. Good luck.
