Series X and Hisense U6g
opethfan
Hello.
I just got this tv. I have an Series X and when in enhanced hdmi mode everything in the game looks washed out. I've calibrated my settings using the Xbox and it's still washed out.
I'm looking for any help on fixing this or setting recommendations
Also the Xbox just released Dolby Vision for gaming, does this tv support that?
Indiana Jones
Have you calibrated it? because the picture settings might need adjusting on a per mode basis.
Also make sure the video format being output by the Xbox matches the TV, if they mis-match then it will look washed out.
As for what it supports there is an option on the Xbox to view details, that will says what is and isn't supported.
opethfan
Yes, I calibrated the tv and HDR recommended by the Xbox.
I have it an HDMI 60hz port and set it to enhanced instead of sdr.
It look like it supports everything but 120hz according to the Xbox. Being that gaming Dolby vision is new for the Xbox I'm just hoping it won't cause burn in and when in use there's seems to be much lag on online games like cod.
Thanks for the info
