Series link on Sky+
Discussion in 'Sky Digital TV Forum' started by dazgwinn, Jan 16, 2005.
  1. dazgwinn
    dazgwinn
    Apr 6, 2001
    153
    u.k
    +8
    I've had my Sky+ now for six weeks now and i am at a loss why so many of my series links are failing. I guess that approx 60% of all my requests for series links are failing and that the problem is not just with any particular satation but is pretty much randem.Is it just that bad or is there a problem?Cheers Dazgwinn
  2. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    try doing the series link on the day that the programme is on. e.g sunday, sky one, 11pm. you've got that in the personal planner to be recorded click series link now and you should get it. because the tv guide shows a week in advance so you will be able to get the series link to work, then after that you don't need to do it again as it is series linked!?
    or, run housekeeping, do a software update and see if that cures it?
    jammy
  3. HMHB
    HMHB
    Nov 11, 2001
    25,611
    Nottinghamshire
    +3,965
    I've not had any problems with series link so far, but only have about 6 set up at any one time. Which programs in particular are failing, maybe someone else can try them at the same time to see if it's just happening on your box ?
  4. dazgwinn
    dazgwinn
    Apr 6, 2001
    153
    u.k
    +8
    its happening om FX with NYPD Blue,E4 with ER and on Channel 4 with Cocaine.Thats just whats failing at the moment!
  5. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    Series link will go further forward than a week, if the program is off the air for a short while (eg Christmas) then it will disappear from the listings but will come back a week before the next program is aired.
    I've never had a series link fail. Failures may be down to the broadcasters or the box.
  6. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,077
    I'd be happy to set up a series link for ER on E4 if you want. This is the only one I watch out of those 3 and it would be useful for me too! I'll set the series link for the Thursday 10PM showings - Ok?
  7. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,077
    Bit of a problem. Had severe wind outside our house on Thursday night and this dislodged something on my sky dish! :mad: Resulted in a cable hanging from the dish :eek: and no signal being recieved by either my sky+ or second sky box. Therefore don't know if the series link worked or not :rolleyes:
    Engineer coming from Sky to fix it on Monday (FOC :thumbsup: as it's apparently covered by my sky+ warranty) so I can't check until then.
