Serial RS-232 help wanted on the AVC-A1se
Discussion in 'AV Receivers & Amplifiers' started by m0v1em4n, Aug 7, 2002.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    833
    Derby
    +49
    Hi all,
    is it still possible to use the newly updated extended RS-232 codes on the AVC-A1se, if not does anyone have the codes for the AVC-A1se
    Also some help in understanding the codes would be appreciated, are they as simple as they look? i would presume not :confused: I.e would the "pwstandby0x0d" command put the amp in the stand by mode,
    What i would like to achieve is control my amp via Girder and a serial plugin.
    any help or info would be greatly accepted :)
    THanks in advanced
    Steve Morris
