Serial commands for PWD6
Discussion in 'Plasma TVs Forum' started by rectorydp, Nov 26, 2004.
  1. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    I'm looking at using the serial terminal on my Panny to integrate control with my home automation. However, the doucmentation in the operating instructions is fairly basic. Does anyone know if it is possible to send more commands than those listed, ie power no/off, volume, mute, input selection and screen mode.
    I also wanted to use the interface to find out the current state, eg screen mode. Does anyone know if this can be done - perhaps formatting a command with a ? for the parameter? I will do some testing but if anyone has the information it would be very much appreciated.
    Many thanks
    David
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    david if you are in the UK a panasonic business systems dealer will have the info whether they will give/loan/sell it to you is another matter i suggest you contact a few...
  3. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Yes, that is probably worth a try. I thought someone here might have the info as it appears to be a very well informed forum.
    Any suggestions for a dealer who is likely to help on this one?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    the one you bought the panel from?
  5. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Well I guess I asked for that! Yes, they will be my first port of call...
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Welcome to the forum mate :hiya:
  7. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Thanks - Are you just trying to boost my number of posts! :D
  8. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    David,
    Who's automation system are you using? Have you looked in the Crestron forum?
    Which Panasonic document do you have? Do you have the four page document PDP Control Command (via Serial Interface) PDP005
    Model: TH-37PWD6, TH42-PWD6, TH-42PHD6, TH-50PHD6
    Paul
  9. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Paul
    I am using a combination of things, some home-built and some purchased. My main controller is actually Homeseer. I guess I could have a look over at the Crestron forum. I certainly haven't seen anything on this come up on the UK Home Automation forum.
    David
  10. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Paul
    I haven't seen PDP005 at all. I did some searches on the web to find stuff , including Panasonic sites (what a waste of time they were!). I've only got operating instructions. Do you have a copy that you can provide. :lease:
    David
  11. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
  12. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Dave, Just sent a PM
    Paul
  13. rectorydp
    rectorydp
    Nov 15, 2004
    54
    Shropshire
    Paul
    That helps a lot thanks. I couldn't find any useful doucments when I searched in the Panasonic site. When I put the model number in I kept on getting a message to say no documents found. :confused:
    David
