separte or all in one package
Discussion in 'AV Receivers & Amplifiers' started by mkendall, Sep 3, 2001.
  1. mkendall
    mkendall
    Please help!!
    i have £500 pound to spend on a dvd ,amp and speaker package.I've looked through the magazines and am just not sure what to get the pioneer nsdv55 all in one or get separtes<br />any advice will be great
  2. KAO
    KAO
    I think you might struggle to get seperates for 500 quid, unless you can get a package via Richer Sounds or somewhere. Seperates will almost certainly get you better sound for a given outlay, but there is a minimum amount you'll need to spend.
  3. hobbes
    hobbes
    the pioneer nsdv55 is a HT good system. You can get it for about £484 (pricebeat at LE Concepts)
    You could consider the Toshiba 210E (£189). With the Videologic Digitheatre DTS (£320). Both have got some damn good reviews. And the DTS has a built in decoder/amp.
