SEO Friendly URLs
Dancook
Hey all,
I've been looking into creating SEO friendly URLs.
It's an Apache/Coldfusion website, I have found you can use Apache's mod_rewrite to rewrite urls from say
yourdomain.com/product.cfm?category=books&product=23
into this.
yourdomain.com/product/books/23
But what methods do I have to rewrite the URL into
yourdomain.com/product/books/harry-potter-and-the-dangerous-pebble
Can this be done at Apache level, it would need to know how to get the title, is this possible?
Or will I have to do it at Coldfusion level?
Achy
Established Member
I'm guessing that the products are coming from a database.
If not you **could** do it at Apache level, but you'd have to set up the rewriter for every product :thumbsdow
So you're be better off using a combination of both...
becomes
yourdomain.com/product.cfm?category=books&product=harry-potter-and-the-dangerous-pebble
Then use Coldfusion to select the product from the database that matches the title supplied by the "product" element in the url.
Or... look at the url of *this* page for example ... it combines the threadid with the thread title.
So in your example it would become...
yourdomain.com/product/books/23-harry-potter-and-the-dangerous-pebble
You could then use the apache rewrite with a regex to select the first numbers to use as the product id.
Dancook
The links aren't all dynamic, so I can't populate existing links with the "product title", unless I pass it through a page to add it...
but then if i'm passing it through a page to add it - then that page could just create the friendly URL.
Though I'm not sure on the best way of doing that currently.
Dancook
Ok I haven't found a definitive guide yet..but here's the logic I think I need to follow, correct me if i'm wrong
URL.cfm?id=xxxxx
redirects to
/url/id-title/
Which goes to a 404 error handler, which then 'includes' the original page.
This way you get to keep your special URL in the address bar right..
Dancook
I think I can wrap this up now, I'm going to consider writing these files so they actually exist in the new directory structure.
If anyone then enters on id= it will redirect to the 'static' page, which just includes the dynamic page.
As long as the technical services team don't see any performance issues with this :) then it's probably a go.
Amazon Fire TV Cube Gen 3 Review: Coming Soon
