Hi all,
I've been dying to get into large screen viewing for ages now and last night bought a 2nd hand PJ. It's an NEC MT1000, got it for a fantastic price and couldn't be happier.
I have a couple of questions I'd be grateful if you could answer.
The lamp life is at 511 hours and the manual quotes changing it at 2000 hours/6 months. Should it be okay to delay changing it until the 2000th hour?
Can you recommend a good place (price wise) to get a new lamp?
Is it worth buying one now? I'm worried that as this PJ is nearing 5 years old, they may discontinue the bulb required for it.
I have made a screen out of an old coffee table!! hehe (yes really!!). The picture is unbelievable even before painting it white/grey. Can you recommend the best paint/covering I could use to improve the picture.
If anyones interested, I'll be taking some picture and will put them on a site soon.
Cheers all,
Glen
Cheers all,
Glen
