Sennheiser PC 350 SE Setup Advice?
Discussion in 'Computer Components' started by Carnagerover, Feb 2, 2014.
  1. Carnagerover
    Carnagerover
    Jan 21, 2004
    3,682
    Rother'ham (donny lad)
    +223
    Hi all,
    I have a Sound Blaster Recon 3D and I just bought a pair of Sennheiser PC350SE's, I have plugged them in and they work very nicely on the audio front, really pleased with them. However I have a question regarding the mic, should I be using the +30dB option, because if I don't the microphone sounds really low when I listen back to a recording even on 100% mic volume.
    However does using the +30dB make the mic quality worse?
    Not really used a analog headset before mainly had USB before.
    Thanks :hiya:
  2. Carnagerover
    Carnagerover
    Jan 21, 2004
    3,682
    +223
    Anyone drop any knowledge on this
  3. cokker
    cokker
    Apr 30, 2008
    918
    46
    Norwich
    +118
    The only thing really to do is set up the microphone as best you can and then play a few multiplayer games or skype etc and ask if they can hear you ok.
    If they say it's a bit distorted try lowering it to +20dB with 100% volume until you hit a sweet spot :smashin:
    I currently have my desktop microphone at 50% volume and +20dB boost.
  4. thedude
    thedude
    Oct 18, 2004
    10,162
    Swindon
    +2,067
    I just ordered this, i get mine tomorrow. How you getting on with it?
