Sennheiser IE8 Fix
Discussion in 'Headphones, Earphones & Portable Music' started by SBanga, Mar 5, 2013.
  1. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +7
    I've got an old pair of IE8s and thought the cable was faulty so ordered a new one. However, it's actually a fault with the headphone connection in the right headphone. Basically, a tiny strip of metal has sheared, leaving the connection point ever so slightly large for the pin. I was thinking to just put a tiny amount of foil around the pin to make it fit better.
    My question is, does ordinary food wrap foil conduct electricity and would this solution work effectively?
    I can add photos this evening if it helps.
    EDIT: It really was a tiny hole and I had to use the smallest amount of foil but it's worked :)
  2. beatbeast84
    beatbeast84
    Nov 10, 2011
    3
    +5
    How permanent is the solution. Is the sound quality still the same.? And how long have you had them for, they may still be covered by a warranty. Have you tried contacting the supplier?
  3. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +7
    It's not a perfect solution in that if I remove the plug, the foil will most likely fall out. But as long as the connection is made, it is pretty much spot on and I can't tell any difference in sound quality.
    The earphones are over 3 years old now so not covered by warranty. Still going strong though.
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,579
    +6,591
    Maybe still ask Sennheiser and email them photos. Even if they cannot offer free servicing it will only have cost your time up to then
  5. beatbeast84
    beatbeast84
    Nov 10, 2011
    3
    +5
    True. They might just be able to do something for you. Good luck
  6. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +7
    Thanks for the tip guys. Emailed them asking about a repair and received a reply within the hour to return them for a replacement. Kudos to Sennheiser UK. Happy days.
