Senhnheisser RS175 bug in Panasonic 65HZ1500Z
omega939
I have Senhnheisser RS175 plugged it into the optical digital to my Panasonic 65HZ1500Z. The TV's firmware is updated and Apps like Netflix, Disney+, Prime is not producing any sound. But in Youtube and youtube kids, it's working fine. Anybody here have some problems same as mine? Or is this a bug issue ?
JayCee
Have you tried power cycling your TV?
Do you have sound from the problem apps from the TV speakers?
omega939
There is sound from the speaker of the TV. When i use the analog input there is sound as well. But when i use the optical cable and switch the headphones to optical, no sound from netflix and disney+. Only youtube, neon apps are with sounds. I bought also a 3 way optical splitter to see if the problem gets fixed but still a no go.... A bit odd right?
JayCee
Go into your TV's sound menu, look for the digital audio out setting and try setting it to PCM.
