Sending video to projector via AV sender
Discussion in 'Projectors, Screens & Video Processors' started by donkeymagic, Jul 27, 2005.
  1. donkeymagic
    donkeymagic
    Has anybody used a wireless av sender to hook up their dvd/sat to a pj? I am just wondering if there is a huge difference in picture quality when using one of these.
    I am currently looking for a pj around the £1000 mark but want to keep cabling to minimum if at all possible. As I want the pj ceiling mounted I could do without the hassle of pulling up floorboards and chasing out walls etc.
    Any info or other suggestions would be appreciated.
  2. summat
    summat
    Dec 16, 2004
    90
    Preston
    Don't most video senders work with a composite video signal?, and the bandwidth of the link probably won't be so great?, if so, stay clear of them.
    If you're in the market for a £1000 projector then be prepared for a fantastic high-fidelity, high resolution, beautifully crisp display. Put a (poor) RF link in there and you can kiss all that goodbye.
    If, however, you can find one that takes component, or RGB, and transfer those individual channels with a high-bandwidth band, then I'll eat my words. But don't expect any such device to be readily available, or cheap.
  3. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    Alternatively, if you really really really cant use cables... You could try using 3 AV senders, one for each channel of a component signal....
    Never tried it and I doubt there is anybody else who has,,, but could be a solution....
