Sending Sky+ to the kitchen?
Judders
I'm having a new kitchen fitted soon and want to fit one of those under-unit LCDs. I'd like to be able to view Sky+ in the kitchen, but there's no requirement to view different channels to the main TV.
Can I just connect the kitchen LCD to my Sky+ box via the RF2 Out? Or is it not that simple?
Thanks in advance.
Jud
C
cmo
Yes, you can simply connect RF2 to the additional location which will work fine - you can also set the picture format - standard or widescreen which can be different to the main location.
Of course should you wish to want to change channels in the kitchen then you can simply add one of Skys or similar small Infra-red eyes as the RF2 output has a built in infra-red receiver - very simple.
C
cmo
Judders,
You may also wish to know that you can change the RF output channel number transmitted along the aerial cable by going into Services-System Setup, then press '0' , '1' , 'Select' , a new menu will appear and you can change the output channel (frequency) to a different one, this can be useful if you find you get interference using the existing output frequency when you tune in the kitchens TV.
Also if you wish to use the Sky infra-red eye in the kitchen then you will require this same hidden menu to turn the eye on (RF outlet power supply).
Chris.
Judders
thanks Chris. I'm sure that last bit of advice will come in handy. If it's possible to get interference, you can be sure I'll get it :rolleyes:
Jules Tohpipi
Sorry to possibly hijack the thread here - and I might be chronically misunderstanding what you've written above - but could you be watching one Sky channel in the lounge, whilst watching a different Sky channel via the RF2 output ? Does the twin tuner in a Sky+ box allow you to do this, routing a different channel via RF2 ?
Judders
I hadn't intended to watch two different channels (but it would be a bonus!), so I'm not fussed if Sky+ only outputs 1 channel.
B
brainfry
CMO, thanks for the installers menu tip, sorted my problem out on the 2nd tv a treat!
edyjchan
Sorry guys....I'm new and naive in technology.....I have just bought a 15 inch LCD for my kitchen, planning to get an indoor aerial for it but after reading your threads, I found that I might not need to...... my sky+ box is in my living room....how do I go about transfering my sky signals to my LCD in the kitchen.....don't really understand what RF2 mean? Please help and thanks in advance.
Tuscan
RF2 is the extra output connector on the back of the Skybox
