Sending Sky Round The House
Discussion in 'Sky Digital TV Forum' started by KERRYBR, Mar 17, 2005.
  1. KERRYBR
    KERRYBR
    Mar 17, 2005
    94
    I am having sky+ and multi room installed next Monday (switching from NTL).
    I intend having the sky+ in the lounge plus the extra box downstairs also in the next room for the son and me to watch footy etc. I would also like to have sky in the bedrooms but am not sure the best way to achieve this.
    I could run a solid cable upstairs but it would look crap and I dont think the misses would be too impressed by having a cable clipped to the wall, plus the bedrooms have laminate floor so it would be differcult to run.
    I am considering a wireless setup but am I right that the remote extender would not work, so I therefore could not control either of the boxes from upstairs unless I run a cable. Has anyone tried a wireless option and does it work ok ?
    any help gratefully received
  2. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    I have no problems with a wireless transmitter and the remote channel changer.
  3. KERRYBR
    KERRYBR
    Mar 17, 2005
    94
    Thanks Lynx but which ones are you using ?
  4. lynx
    lynx
    Jan 20, 2002
    4,653
    It always rains.
    +302
    All in One, picked up from Safeway for ~£20. A word of caution though, it's composite only.
  5. KERRYBR
    KERRYBR
    Mar 17, 2005
    94
    thinking of getting a AEI Digisender Gold, can anybody recommend one
  6. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,614
    48
    Lancashire
    +55
    Maplins have a sender on offer at the moment - £39 works fine for my +(including remote operation). If you look at the senders they sell, not all work with NTL or +, often revealed in the FAQ on a product. They will also sell multiple receivers.
  7. LG Chet
    LG Chet
    Nov 23, 2004
    125
    I use the maplins one trasmitting to 2 additional rooms and it works a treat
    The only prob u get with wireless senders is that they go mental when the microwave is on!
  8. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Try plugging it into the telly and not the microwave :rotfl: :rotfl: :rotfl:
  9. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    Sorry, couldn't resist.
    I know what you mean :thumbsup:
  10. KERRYBR
    KERRYBR
    Mar 17, 2005
    94
    are the maplins ones scart connection only as I only have 1 scart on the tv but also have red/white/yellow inputs available
  11. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,614
    48
    Lancashire
    +55
    They are Scart. The FAQ for the senders list what you need. The unit has a small socket, not unlike a headphone. The supplied lead plugs into it & has a scart at the other end. The leads are available with Av type jacks as an extra (Scart included as standard).
