Sending Back Pioneer DVR-420 - junk!
Discussion in 'Blu-ray & DVD Players & Recorders' started by bluesfan, Jul 8, 2004.
  1. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    To say I'm disppointed in this unit would be an understatement. Is this the same company that made the dvr-7000?
    The noise from the HD and fan is just incredible. First the HD starts up with a loud whirl, then the fan that's even worse and equivalent to an electric toothbrust (a cheap and nasty fan mad in china). Even on low tv volumes without playing through the unit the noise is obtrusive. My room is 12x12, I can hear it from in the hall from on. Worse the HD doesn't power down at all when not in use but emits a constant loud buzz.
    These units may do everything but the build quality and slim design means the fan is small and runs at high speed (like the one on the top of a PC processor), rather than a thicker unit with larger (quality) fan that runs slower.
    If I just want to sit in my living room I would have to make sure the unit is off. I'm sure if you just power this thing on when playing 'loud' dvds it might not bother you, but most people leave these things on all the time (for overnight recordings for example). I can't believe people find the noise acceptable. Unless they're going deaf!!!
    It's going back. The engineers need to go back to the drawing and sit in a living with no sound to hear these things.
    End of Pioneer rant....end of 420
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,200
    2
    +3,674
    Is it me or are HD's getting louder? My Yamaha 1300 sits and makes a barely audible purr, the HS2 a more audible thrum and my brothers new E-85 (for which he paid less than my HS2 :mad: ) can be heard over quiet telly passages. I appreciate that cases are getting smaller and drives bigger but it does smack of idleness on somebody's part.
  3. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    Afterall my laptop isn't that noisy and that has a hard disk. I think Pioneer are sticking in cheap hard disks and cheap fans that will last barely two years.
    These things turn your living room into an noisy office.
  4. dude1971
    dude1971
    My Panasonic has a noisy fan but sometimes it's very quiet and other times it sounds like a motorbike being revved outside the front window. I'll wait till the e65 is available at Richer Sounds before I take it back though ;-)
  5. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    Good luck. If anyone finds a 'quiet' dvd recorder with or without a hd please let me know. I'm now reconciled to a machine with no hard disk.
  6. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    My Pioneer 5100 and Panasonic HS2 have no discernible noise from HDD after a few seconds at startup.They do sit inside a cabinet with glass doors but I would not have thought that would make that much difference
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,775
    Warwick
    +2,676
    It does - I have just moved my previous Optimum Slimline AV shelving upstairs because the 'open' design is no longer good with todays machines (most of which have a fan of some sort).
    My new cabinet, enclosed at the front by glass doors, masks any noise from the components wonderfully.
  8. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    The issue here is cheapest. The Pioneer ax3/5 makes barely a purr from its fan. Why do these dvd recorders have to make so much noise. Small fans, like the one put in the new Pioneers don't last.
  9. PepeDuran
    PepeDuran
    I have a Pioneer 510 DVD Recorder with 80Gb hard drive and its very quiet.
  10. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    I can believe that. I think the new range must have substantially lower production costs (no jog dial for example). Very un-Pioneer like.
  11. DWSpiro
    DWSpiro
