send TV signal to PC - Slingbox/Digisender?
Discussion in 'Desktop & Laptop Computers Forum' started by rpopo, Aug 27, 2006.
  1. rpopo
    rpopo
    OK,
    I'd like to be able to watch TV from my digital set top box in my bedroom. I was first looking at the Digisender, which seems fine, but it looks like it may interfere with my wireless lan. I'm therefore thinking about the slingbox, which has the added advantage that I could use it on my PDA and over the internet (no great ned for that at the moment, but you never know). Anyone think this is overkill, or is it the best solution?
    Next question - if I want to add the slingbox to a wireless lan, I think I need a bridge - can anyone recommend one? - do they vary greatly in quality, or should I just go for the cheapest I can find?
    Also, please see my other post here:
    http://www.avforums.com/forums/showthread.php?t=388033
    which is asking about sending HD content from the PC back to the TV.
    thanks
