jimmynewshoes
Hi all,
I need a 3D Blu Ray player and couldn't work out whether:
1. It would be best to buy a cheaper player with one hdmi output - connect this to the AV receiver
2. Buy a more expensive player with two hdmi outputs - connect hdmi1 directly to projector for video, connect hdmi2 to receiver for 7.1 audio
Option 1 means the video goes via the receiver - is this good/bad?
I guess option 2 means that the AV receiver doesn't 'interfere' with the video, not even sure if it would be an issue anyway.
Would appreciate any advice here - perhaps you can save me a hundred bucks!
Am slowly trying to get my head around this simple-ish family room AV entertainment setup.
Thanks!
- Have got an Epson 5010 projector
- Am thinking of buying a Sony STRDH820 AV receiver with 7.1 setup
- Am thinking of buying a basic Freeview HD set-top box for normal TV viewing - only a small amount of this is 5.1 surround so would use left/right speakers for stereo sound. Only very little of this might be in 3D in the future - this connects into the AV receiver directly.
Thanks!
