Sell 70-200, buy 100-400is?
Discussion in 'Photography Forums' started by Gordon @ Convergent AV, Apr 27, 2007.
  1. Gordon @ Convergent AV
    Jul 13, 2000
    14,236
    +3,101
    ANy thoughts? I got the 70-200f4l when I had my 350d but now I have my 5d it obviously doesn't seem as long....and when I had the 350d I had occassion to want an extender. Of course my 70-200 is only worth around £300 s/h I guess so it's going to hit me hard if I do it...has anyone done such a similar thing? Does anyone have a 100-400is and would like to comment on its quality?
    Gordon
  2. stevegreen
    stevegreen
    May 14, 2001
    8,746
    in my Hymer
    +921
    h4rri had one, he's your man :)
  3. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,383
    113
    Devon, Sussex or somewhere inbetween.
    +552
    I think he changed his mind about selling and has still got it.
    As for the quality of the 100-400 I tried one out back in march and was very impressed with it right up to 400mm.
    It's got a 2 stop IS system which should make it more usable than a non IS 70-200 although you obviously pay quite a price for it.
    The drawback for me, other than it's price tag, was the weight of it - it's twice the weight of your 70-200 f/4 L! It doesn't make it unusable but it can get annoying.
    I plumped for the 70-200 f/4 L IS in the end simply because I think I'll take it with me more often.
  4. Chunder
    Chunder
    Oct 27, 2005
    593
    28
    +37
    Iwent for the 300mm f/4 L IS instead of a zoom, as I almost always used the longest end of the zoom... I also got the 1.4x extender, so I'm using an equivalent of a 420mm IS lens on my 5D - and I'm really, really happy with it!
    I was thinking about one of the 70-200mm family, but decided that it would be too short, and I'd likely never make best use of the zoom range.
    /2p
  5. h4rri
    h4rri
    Mar 22, 2006
    1,988
    +159
    Yep and as Tomato1 says I still have it :)
    The quality is amazing and the reach is great *but* I it is f/4.5 - 5.6 so not the fatest lense in the stable. I don't find this an issue too often, when it is I'm normally on a tripod so can raise the shutter speed :)
    Will dig out some shots for you if you like :)
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,236
    +3,101
  7. h4rri
    h4rri
    Mar 22, 2006
    1,988
    +159
    Animal shots from Longleat all taken with the 100-400
    http://www.randomphotos.net/gallery/2692716#P-1-9
    More taken at Slimbridge Wetlands Trust
    http://www.randomphotos.net/gallery/2688672#142367572
    Can be used for portraits to if you don't mind zooming with your feet ;)
    [​IMG]
    These were all with the 350D and are straight out of the camera [only PP is a little cropping] but if you want a couple of 5D raws let me know and I'll head out to the garden ;)
    Steve
