Self install, Q's
Discussion in 'Satellite TV, Sky TV & FreeSat' started by s_inman, Sep 6, 2007.
  1. s_inman
    s_inman
    Mar 16, 2006
    2,512
    Kendal, Cumbria
    +308
    I have decided to get sky hd in my bedroom, I still live with my parents :thumbsdow But they have agreed to let me have it if I pay the extra £20 a month for muiltiroom and HD. I will be buying the box from ebay, but what kind of cables, connections etc will I need from the dish to the box? I already have a quad LNB.
    Thanks in advance :D.
  2. Rom
    Rom
    Aug 16, 2007
    2,064
    116
    Sheffield
    +746
    Search for CT63 or 'shotgun' satellite cable. This is two (thinner) cables 'suck' together. It will go through a hole made for the cable that sky install as as standard.
    I did this and it made installation a breeze.
  3. D-an-W
    D-an-W
    Sep 23, 2006
    1,795
    +184
    Two lots of coax (Or a dual one) and a phone socket should do you fine...
  4. s_inman
    s_inman
    Mar 16, 2006
    2,512
    Kendal, Cumbria
    +308
    Thanks for the reply, what about m/f connections?
  5. s_inman
    s_inman
    Mar 16, 2006
    2,512
    Kendal, Cumbria
    +308
    Just noticed I need F, :smashin:.
  6. tonkie
    tonkie
    May 16, 2005
    3,686
    Guernsey
    +897
    Coax cable is not for Satellite
  7. D-an-W
    D-an-W
    Sep 23, 2006
    1,795
    +184
    What? Of course it is, sure it has a different impedance but it is still coax...
  8. tonkie
    tonkie
    May 16, 2005
    3,686
    Guernsey
    +897
    If you go into a retailer and ask for coax cable you will just get that, but if you ask for satellite cable you will get a different cable.So for someone who has not got any idea as I think S_inman does not as he is asking for advice on what cable he needs this could be very confusing let alone expensive.
    http://www.satelliteonline.co.uk/cable_large.htm
  9. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,038
    Poole
    +10,904
    Satellite frquencies from the LBN are much higher than terrestrial and terrestrial cables has high losses at satellite frequencies.
  10. s_inman
    s_inman
    Mar 16, 2006
    2,512
    Kendal, Cumbria
    +308
    Thanks guys :thumbsup:
  11. D-an-W
    D-an-W
    Sep 23, 2006
    1,795
    +184
    Yes, I know...but it is still coax!
    I figured if the OP knew what a Quad LNB was he would know to ask for Satellite Coax when purchasing :rolleyes:
