Selective colouring in PSE 6 - Help Please!
johnaalex
OK, I admit to being easily confused when it comes to using layers etc in PSE 6 and I seldom do any succesful PP other than cropping and minor tweaks. However, today I took one pic that I think would look good if I applied selective colouring to it, I have tried to no avail to do this. Can anybody either tell me a step by step method or point me to an "idiots' guide" website.
BTW - I have the NEF file and Capture NX so I suppose I could use that, but again I am clueless :confused:
Thanks!
dmx005
Thanks!
Hi there,
When u say selective colouring, there are a number of ways (like everything in photoshop!) to achieve this. I use the Hue/Saturation (Ctrl + U) feature a lot when I want to tone down colours or increase vibrancy.
If you want to change certain colours only, then u can use the 'replace colour' (image/adjustments/replace colour) to replace a single. I dont have PSE6 so not sure if the functionality is the same as CS3 but if you explain a bit further what u are trying to achieve I will try to help.. :smashin:
Edit: Oh, make sure to always duplicate your original layer & u can use the lasso (L) tool to select shapes/objects which u can re-colour...
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
