Selecting Inputs on Pio 435
Discussion in 'Plasma TVs' started by nheather, Aug 23, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    15,404
    Horsham, West Sussex
    +4,556
    Can anyone with a Pioneer 435 XDE confirm whether the input sources can be selected directly by a single button push or a guranteed sequence of buttons.
    The hand control looks like you can do it but I need to be sure.
    I ask the question because I would be looking to be able to control it from a Pronto controller is able to select the right channel on the panel and on the AV Amp at the same time.
    Actually, I'm really interested in the 436 but since that isn't out yet I assume no one will know about that one but I susepct it will be similar to the 435.
    Thanks for the help.
    Cheers,
    Nigel
  2. ikon66
    ikon66
    Mar 22, 2005
    400
    Tyne & Wear
    +8
    the controller has 4 buttons on the top each assigned to inputs 1 to 4 :smashin:
  3. nheather
    nheather
    Oct 6, 2004
    15,404
    +4,556
    ikon66
    Thanks for the response. Do these buttons have any sub-menus or toggles. For example
    Input 2 has both SCART and Component
    Input 3 has both SCART and HDMI
    How do you choose between these - is it a matter of continuing to press the 'Input 2' button to toggle through options or can you only have one of the options (SCART or Component) which you have to pre-configure.
    Likewise TV and Freeview seem to be on a toggle button. Is there a guranteed sequence that will always select TV and another that will always select Freeview.
    Thanks again for the help.
    Cheers,
    Nigel
  4. ikon66
    ikon66
    Mar 22, 2005
    400
    Tyne & Wear
    +8
    you have to set up the inputs in on screen menu. When they are set you can just use the 4 buttons to select
    there is a dual button which toggles between analogue and digital tv
    you can download the manuals from the pioneer site
    http://www.pioneer.co.uk/uk/content/support/support/manuals.html
    click the link then search for the one you want
    hope that helps
    Paul
