Seleco SVT180
sraper
I have just discovered a Seleco SVT180, gathering dust in a cupboard where I work. I have no idea of its condition.
Does anyone know much about these projectors? What is its max resolution when connected to a PC? I assume that its tubes are 4:3 and not 16:9. I am wondering if it worth my asking if I can take it home! Though not sure if the wife will like it fixed to the ceiling of our living room!!!
Chris Frost
SVT180 is a video only projector. It's based on the SVT150 - so it is the same set-up procedure as a 150 - but it uses the brighter Sony tubes instead of the Toshiba ones fitted to the 150.
There is a 9 pin D socket marked Analogue/TTL but you're only going to be able to feed in RGB from a Skybox or a DVD player with a modified cable. It's simpler to go into the SCART socket instead.
This projector design predates 16:9, so you should set your sources to 4:3 Letterbox to watch anything widescreen.
If its free then definately get hold of the projector and have a play. Its a great way to learn convergence.
Regards
