Seleco svt 150
Discussion in 'Projectors, Screens & Video Processors' started by myyamada11, Jan 11, 2005.
  1. myyamada11
    myyamada11
    anyone have any ideas on the seleco svt 150. I have owned fron new with approx 1000 hours use on it. The thing just switched off(used to do this regularly before and go into standby.) and now wont power up. The led display is powered but the digits dont light up and the convergence assistance lamps also lights up when switched on. Fan is also working but no other function apparent....pls help :lease:
  2. atrade
    atrade
    I have the 150 too, it does this for me as well sometimes but if I press the power button on and off fast enough it suddenly comes to life!
    Sorry I haven't got any better suggestions!
  3. mintminty59
    mintminty59
    Jan 19, 2005
    55
    you have a common fault which is located in the PSU. Its usually a dry joint or a cap has dried up and failed. Hope this helps
