seleco svt 150 service
Discussion in 'Projectors, Screens & Video Processors' started by jesmond14, Sep 28, 2004.
  1. jesmond14
    jesmond14
    hi there can anyone tell me how to get rid off flashing lights red,green,blue. horizontal lines right at top of screen for this seleco svt 150. i have tryed to mask them but would like to get rid of them compleatly. is this a norm for this model? thanks. jes
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    These are the AKB lines which are there to keep the red green and blue tubes in colour balance relative to each other. They should be there and visible.
    If you have an electric screen with a black case you should be able to park the lines on the case so they don't show up as much.
    Regards
  3. jesmond14
    jesmond14
    thanks for your help chris now i can accept that there is no problem whith this crt projector . thanks. Jes.
