Seleco SVT-150 Black And White Through PC
Discussion in 'Projectors, Screens & Video Processors' started by atrade, Apr 25, 2005.
  1. atrade
    atrade
    Im trying to connect my PC to the Seleco 150 using the TV-Out on a Radeon Card.
    It displays the picture fine but only in black and white :(
    Anyone any ideas?
  2. crispybig
    crispybig
    Sep 28, 2004
    273
    +6
    I would guess it's an s-video output going into a composite input.
    I don't know about the Radeon in particular, but most cards will let you select either type of output (in the software).
  3. aerobic247
    aerobic247
    Jun 29, 2004
    180
    East Kilbride/Glasgow
    +13
    Hi atrade
    I have by barco 701s hooked up to my computer via s-video TV-out.
    I had the same problem black and white on s-video till i realized i had not changed the output from composite to s-video in the Control Panel, Display Properties, :oops:
  4. atrade
    atrade
    Cheers for the replies, think that the composite/s-video out is my problem just cant find anywhere to change it in my settings :(
    Ive got a 64mb Gforce lying about so i'll try sticking that in tonight and see if that makes it more obvious where the setting is
    Cheers everyone!
  5. atrade
    atrade
    Right updates!
    Ive put the Gforce II in the Pc instead and this has allowed me to switch betweeen composite and s/video
    But the picture is still black and white :(
    Im connect the Svideo out of the Pc into a scart block which has a Svideo converter on it, do you think this might be causing the problem?
    And is there any other way to connect my PC to it?
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    Try the S feed from the graphics card direct in to a TV if possible. Does it work OK. Now introduce the SCART block/convertor (??) you mentioned and retry into the TV using SCART. Still working OK?
    Finally connect to the pj, select the correct input (read section 5.3 in the manual). If it's gone B&W now then there's some problem with the input on the projector.
    PS - why aren't you connecting S direct to the pj? It has S compatible inputs.
    Regards
  7. atrade
    atrade
    Hi Chris,
    Thought you'd pop up with a reply sooner or later!
    There doesnt seem to be an S-Video input on the PJ, or am I being blind?
  8. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    Yes, you're being blind :suicide:
    Read the flippin' manual
    That's a pretty big hint :)
