hi, my 420 has developed a problem. while watching a film the red tube developed a fault. when you look into the red tube the picture is distorted but it is fine in the green and blue tubes. there is also, what i can only describe as pulsing coming from the red tube which after a while starts to affect the other two tubes. when i opened the case i found the item pictured which has the following code on it. mpc 60.0134.000 and pc 318.b if anyone knows where this board comes from it would be much appreciated and may solve the red tubes problem.
this projector was beautifully set up by the famous Chris Frost and i'd love to get it back up and running.
regards
john
regards
john
