Seleco SVP350 Manual Conversion
Discussion in 'Projectors, Screens & Video Processors' started by kireland, Dec 28, 2002.
  1. kireland
    kireland
    Having bought this second hand projector some 2 years ago I had a problem with the picture recently that was sorted by fitting a new manual conversion board someone has kindly let me try, with a option to buy.
    The new board is a later design but is missing the Horizontal and
    Vertical adjustments trimmers that my old board has. The Manual for this board refers to adjusting deflections on the handset. When using the handset I do not appear to have access to individual adjustments for each of the 3 CRTs only one common one that moves the whole picture. I have got the 3 grids identical but not on top of each other. All I need to complete the set up is to move the grids and fine tune.
    Can anyone advise what I should do or buy next?
    Thanks in advance
  2. JonMace
    JonMace
    Nov 20, 2002
    2,502
    83
    Kent
    +202
    Do not know the PJ but your message seems to imply that its a CRT, in which case you may have greater luck posting on the CRT forum
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,978
    +2,779
