Seleco SVp 400 ht from ceiling mount to coffee table
Discussion in 'Projectors, Screens & Video Processors' started by cole trickle, Nov 16, 2004.
  1. cole trickle
    cole trickle
    HI
    Crew can someone pls tell me how wth the black remote to change my ceiling front display to desktop display?
    Also can i use the following ISCAN with my my projector http://www.dvdo.com/pro/pro_isu.html
    Apparently they are not making the pro anymore
    Cheers Dale
  2. cole trickle
    cole trickle
    ANybody??
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Cole This can't be done from the remote. It is done by changing some the multipin connectors inside the projector.
    The proceedure will be in the manual but once done the projetctor will require comeplete realignment.
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    Re: ceiling to desktop - as Roland said change the multipin cables inside the projector, and also do the software switch using the remote otherwise the remote navigation keys will work the wrong way!! :rotfl:
    iScan Pro - yes that'll work. Search this forum - similar question asked and comprehensively answered for BenC in the last couple of weeks. iScan Pro makes a big improvement too.
    Regards
    Chris
