Seleco SVP 400-HT Ceiling brackets
Discussion in 'Projectors, Screens & Video Processors' started by ian-500, Mar 8, 2005.
  1. ian-500
    ian-500
    Oct 21, 2004
    340
    2
    28
    Weymouth
    +49
    Hi there.
    Would anyone have/know where I can get hold of some OE ceiling mounting brackets or similar (hopefully not too expensive) for my SVP 400-HT. Should I be talking to Chris Frost?
    Any help would be appreciated
    :lease:
  2. AndyFov
    AndyFov
    Nov 20, 2002
    1,472
    March, Cambs
    +45
    I bought one from Owl, it cost £50. That was just the flat plate that goes on the ceiling, not the hooks which connect to the pj.
    The day after it arrived, I told a friend and he said "oh, you should have said, I've a spare, you could have had that." He did give it me, but I'm fairly certain I sold both with my 400. Will double check, and if I find it in the spares bin I'll let you know.
    FWIW the bracket isn't specific to the 400, it fits the 3xx and 500 series too.
  3. ian-500
    ian-500
    Oct 21, 2004
    340
    2
    28
    Weymouth
    +49
    Thanks for the info Andy. :)
    If you do manage to find the 'other' one then great. If not, I'll contact Owl and see what they have to say.
    Do you know of any other manufacturers that make ceiling mounting brackets? I've heard someone mention 'Unicol' before. Ever heard of them?
    Ian.
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    http://www.unicol.co.uk/
    Superbly engineered but rather expensive and a bit too industrial looking for most livingrooms.
    Bracket comprises three parts - ceiling plate (c. £32) + extension pole (c. £15) + adapter plate top fit your pj (c. upwards of £100)
    Part no of Unicol adapter plate for SELECO SVP 3xx/4xx/500 series is 0044.
    The Owl route is a better option. Pj hangs closer to the ceiling so it looks neater and it costs less.
    Regards
  5. ian-500
    ian-500
    Oct 21, 2004
    340
    2
    28
    Weymouth
    +49
    Thanks Chris.
    I know I'm being cheeky :D , but as your the Seleco guru, how much do you charge to help someone with their PJ installation? I'm not far from J10 M42.....................
    :lease:
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Drop me a pm with your phone number and I'll give you a call.
    Regards
