Seleco svp 350
Discussion in 'Projectors, Screens & Video Processors' started by Baldtop, Oct 23, 2004.
  1. Baldtop
    Baldtop
    Just bought my first projector for bargain price.
    that is if I can get a remote and user manual for it.
    Focused it and did the convergence ok but i think i need the remote to adjust the masking, Tune the TV receiver etc.
    Does anyone know the remote type I will need, or even better
    have one they are willing to part with.
    Many thanks
  2. Baldtop
    Baldtop
    Would it be the RC3000 I'm looking for (as this is the complete setup remote for the
    SVP 420 I'm thinking that this might do the whole SVP Range).
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    The original remote for the 350 is the RC3500. It's the one with the Teletext and Audio control buttons. You can complete a full convergence with this remote. Last price I had was about £35 but that was about 4 yrs ago.
    The RC3000 is the service remote. It's more expensive and doesn't have the everyday t/text & audio controls but it does make set-up a bit easier. Last time I looked they were getting on for £100
    Regards
  4. Baldtop
    Baldtop
    Many thanks Chris
    Gonna give Owl a ring in the morning to see if they can help with one or both of these.
    Cheers Nick the Newbie
