Seleco Remote Control
Discussion in 'Projectors, Screens & Video Processors' started by DexS, Aug 1, 2002.
Thread Status:
Not open for further replies.
  1. DexS
    DexS
    HI
    I am from Singapore and I owned the Seleco SVP 400 for nearly 5 years. My calibration remote model RC 3000 failed on me and the dealer in Singapore is no longer doing Seleco CRT. I thought of getting it in UK so I need some advise on where I can possibly get them online/mail order.
    Many Thanks
    Dexter
  2. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    You will be able to buy a replacment remote control from Owl Video Systems. Owl are the sole distributers of Seleco/Sim2 products in the UK. I had an accident with mine and Owl provided me with a new remote.
    You can contact Owl on Tel: 01825 760246 or email them at [email protected]
    Regards
    popeye
  3. DexS
    DexS
    Thanks Popeye for referring me to Owl. I have send them an email and got no reply after 4 days. Are they the biggest Seleco dealer ?
  4. popeye
    popeye
    Feb 12, 2002
    779
    19
    Leeds
    Owl video Systems are not a dealer. They are the sole distributers of Seleco/Sim 2 products in the UK. My own experience in dealing with Owl has always been positive. I'm suprised they haven't got back to you.:confused:
    Try contacting Owl on the telephone number I provided. It may be the case that they can deal with you directly or they may refer you to your nearest dealer to order a remote.
    Hope this helps.
    Regards
    popeye
Thread Status:
