Seleco Data Graphics 700
Discussion in 'Projectors, Screens & Video Processors' started by Metric, Apr 20, 2001.
  1. Metric
    Metric
    anyone heard of this unit? is it any good? what would be the sort of price to pay?
    SDG700
    cheers
    Mike
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,058
    The SDG700 is a 7" data projector. The chassis is the basis for a SVD800HT. Although the SVD800 has substantial mods to make it more HT friendly both in picture quality, useability and aesthetics.
    It probably has Seleco's built in doubler inside. This is OK but the unit will show pretty substanial improvements with a decent external video processor.
    Physically it's quite big compared to their usual Home Cinema design cases. I'd expect that around £1000-£2000 would be in order depending on condition. If you've never set up a CRT before I'd recommend getting someone who has to help you. This isn't the easiest to fathom. If you have the instructions though you should be able to work through it yourself if you're patient.
    It has multiple memory locations for different convergence settings and it has enough range in its vertical size adjustment to cope with an anamorphic setting. These can be easily accessed from the handset and programmed in to a Pronto through a macro. So functionality is good as well.
    Hope this is of some use.
    Gordon
  3. Metric
    Metric
    Cheers for that info Gordon...appreciated
    Mike
