seleco 400 plus question
Discussion in 'Projectors, Screens & Video Processors' started by Vixpy, Apr 2, 2001.
  1. Vixpy
    Vixpy
    I have the above and have a small problem (more of a querey actually)
    I have one memory bank set up for 4/3 pal for my sky digital and another 4/3 set up for my playstation becuause they both output slightly different sizes of picture.
    the problem i have is that when playing on the playstation, when it switches between a screens (eg loading to a game play screen.) the projector seems to switch to the sky setting and then back again, its not a major problem but annoying non the less,
    Is there a way around this?
    Thanx in advance
  2. Leon Rees
    Leon Rees
    Do you have the Sky and Playstation settings on the same ratio?
    If you do, change one of them to one of the other 'large' aspect ratio settings (e.g. Cinema) and you should be fine.
    Leon
