Seleco 400 and progressive scan
Discussion in 'Projectors, Screens & Video Processors' started by Vixpy, Jan 9, 2004.
  1. Vixpy
    Vixpy
    Forgive me if this sounds stupid but i have'nt picked up a HC mag for 4 years and so i'm feeling a bit out of the loop.
    My sony DVD player recently gave up the ghost and so i've got a new HK 25, I'm running it throgh an s-video to my Seleco 400 plus, the Projector does'nt like progressive scan being sent to it this way. now the questions;
    Is it that my PJ does not accept PS at all?
    Does it only accept it through Component then?
    I have a component cable on the way , if my PJ does'nt accept PS at all, is there an upgrade i can get?
    I used to be so knowlageable about these things!
    TIA.
    Charlie.
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Hi Charlie,
    S-video isn't designed to carry Progressive Scan for any type of display be it a TV, plasma or projector.
    From memory I think the 'plus versions of the 400 accepts progressive scan. From the Harmon the connection would be component.
    There's a simple way to check your projector compatibility. Press AV/0 on the remote to bring up the input list on screen. Look for a Component input with 32k written along side. That is your progressive scan Component input. :)
    Enjoy
  3. Vixpy
    Vixpy
    Thanks Chris, i'll give it a look
