seleco 320
Discussion in 'Projectors, Screens & Video Processors' started by grahamricho, Jan 13, 2002.
  1. grahamricho
    grahamricho
    Oct 29, 2001
    781
    York
    +20
    would any body now what the ideal settings for contrast ,brightness, colour,etc and what is peaking?also colour temp ,is the factory setting 6500k the ideal setting,,,,,cheers graham
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    The front panel controls should be set corrrectly with a test disc of some sort in the first instance. Use the THX optimisor patterns or invest in Video Essentials or AVIA Guide to Home Theater. Using someone elses settings would be useless.
    6500k is the correct temp to use. It may not be accurate though.
    Peaking is their word for Sharpness. It should, generally, be turned way down.....
    Gordon
