Seleco 320+ Memory Manager
Discussion in 'Projectors, Screens & Video Processors' started by shabbyroad, Jun 24, 2002.
Thread Status:
Not open for further replies.
  1. shabbyroad
    shabbyroad
    I need to switch memory locations when moving between Xbox and DVD player sources on my Seleco.
    Is there a way (via the remote , or via a macro on my Philips Pronto) to load other memory settings without going into the 'install' menu ?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    I'm not familiar with 3XX series really but...
    I guess both sources are same scan rate? Is it possible to give each memory bank a different "aspect ratio" symbol. ie"cinema", "letterbox", "small".
    That way when you hit "aspect" button on remote it cycles through each memory bank?
    Gordon
  3. shabbyroad
    shabbyroad
    that worked a treat !
    I'll see now if I can programme it into my Pronto so I can add it to the Macros I've got.
    thanks Gordon !!
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
Thread Status:
