Seleco 150 lenses.
Discussion in 'Projectors, Screens & Video Processors' started by PaulP, May 15, 2003.
  1. PaulP
    PaulP
    Hi there,
    Firstly, I'd like to say a big thank you to Alan and Kim at Owl Video.
    I ended up with the Seleco 150 which Uncle Eric auctioned off for GOSH a few months ago.
    Unfortunately, by the time I got it, it had failed, but now thanks to Kim's diagnosis I've managed to repair it. :clap:
    The plan is to use the 150 to "test the water" of crt - and then look to upgrade to maybe an 8" later in the year.
    (my other proj is 1024 x 768 DLP - which is much sharper but personally I find the rainbows distracting)
    Anyway, question for you lens experts, the 150 looks a bit soft to me, I've focussed it as best I can, including the electrostatic pots, but even the test grid didn't look pin sharp.
    It has Delta TAC 3 lenses - are these the plastic ones ?
    Is it possible / worthwhile upgrading the lenses on this "starter" proj ?
    best regards,
    Paul.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm with Gordon, the 150 will improve in sharpness with hybrid lenses like HD6 or HD145 but I think it will just show up other shortfalls in the PJ.
    I've got a set of HD6 lenses where one of the outer rings is cracked bit optically are perfect they may be the answer.
  4. PaulP
    PaulP
    Hi Gordon,
    Thanks for that, yes I suspected as much.
    Hi Roland,
    I would be interested to try the HD6 lenses, thanks. I'll drop you a PM.
    Best regards,
    Paul.
