Hi, I’m a total newbie here. I’m 70, so bear with me please. Any one answering please assume I am a 10 year old when trying to explain?
We can only access TV here by Satellite. I’m being driven nuts by the inability to link my Humax HDR-1100S Freesat box to a brand new Panasonic GX700. Despite using any of the available codes I can’t seem to synchronise the Humax handset to the TV. One or two of the codes work, but when changing channels the sound levels can vary enormously from inaudible to deafening., leading to a scramble for both handsets to make adjustments. Also, there is a lip synching problem which appears after a while and gets progressively worse. My dish aerial cable is fed into input 2. When introduced into input 1, the weak signal message appears on screen. I do not have at present a parallel cable to use the Humax box to its full advantage as I know I should.
I also have another Humax/Panasonic set-up in a different room which works perfectly off a different dish. It’s a 500GB one and there are no compatibility problems. The TV is a 2016 TX-50CX70 OB.
I swapped the Humax boxes over, and still no joy.
I then moved the new TV to the other room and connected it to the 500 GB box with both aerials connected from the different dish.
Still no joy.
I’m tearing what little hair I’ve got left out . Anybody help me please, in simple terms?
Thank you.
Still no joy.
Thank you.
