J
jmack
hi guys
not sure if this is to do with my toshiba 42wp16 or my arcam dv88+
on my plasma the settings for pal and ntsc can have different picture settings? or used to be
i have been trying out today new picture settings when i notices on pal i can adjust the tint? never have been abled to do this before and the manual states you cant,
before it use to be grayed out on pal disks so you could not adjust it.
thinking this was weird i treid setting pal picture settings and ntsc to different settings ie +10 contrast for pal then put a ntsc disk in and change that picture setting(follow me)
but they are both same as each other , i adjust one it affects the other.
i have recently upgraded the firm ware on my arcam dv88+ to 4.18
it is selected as auto so is putting out 525p for ntsc and 625p for pal.
i have auto selected as tv type?
any help would be great as i`m stumped.
anyone with a toshiba/panny 4 series could try thers for me with pal disk and see if tint is adjustable?
