seeking help
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by gdavid861, May 13, 2005.
  1. gdavid861
    gdavid861
    May 13, 2005
    15
    3
    London
    Can somebody help me??
    I trying to decide on the best A/V receiver to go with my speaker set (Cabasse Xi - i got them really, really cheap).
    I can pick-up any of the following at a very discounted price, but i don't know which one to choose.
    Denon avr 3805
    Arcam 300
    or Yamaha DSP-Z9
    Is the Yamaha (my prefered choice) going to be to much for the speakers??
  2. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    Hi, you might have more luck if you try asking in the Integrated Amps and receivers section :)
    Steff
    EDIT: Actually it might be worth asking in the speakers section as well what they think would be most appropriate, but most would say listen to the amps and whchever one you prefer is the one YOU should go for... Not what others think is best :)
