Hello all,
I'm in the process of converting from 5.1 to 5.1.4 and have been trying to determine the best compromise for an imperfect room to incorporate the height speakers. Since the heights will be in-ceiling, the placement will be semi-permenant. Diagram 1 is the entire placement map and Diagram 2 is the measurement map I'm giving the installers. Any thoughts/advice on my setup would be greatly appreciated. I wouldn't have been able to get this far without all the great advice in other posts.
Speakers/Receiver (Please excuse the ecclectic timbre matching. I'm in the process of transitioning to full Definitive.)
My sincerest thanks in advance. =)
- Front Left/Right - Definitive Technology BP 7004
- Center - Klipsch RC-62
- Surround Left/Right - Klipsch Synergy B-3
- Ceiling - Definitive Technology DI6.5R
- Receiver - Yamaha RX-V685 (will need to upgrade | only 5.1.2 capable)
- Ear Height - 40 inches
- Ceiling Height - 120 inches (10 ft)
- Surround Height - 42 inches (slightly higher to prevent blocking)
- FL/FR Angle - 26 degrees (slight toe-in)
- SL/SL Angle - 120 degrees (wall mounted)
- FCL/FCR Angle - 45 degrees (ear height to ceiling)
- RCL/RCR Angle - 31 degrees (ear height to ceiling | 9 inches from back wall)
- Overhead side-to-side separation - 96 inches (0.56 width of overall layout - 171 inches)
