Seeing the Denon on-scren setup
Discussion in 'AV Receivers & Amplifiers' started by mariolanza, Jan 6, 2002.
Tags:
  1. mariolanza
    mariolanza
    Help, what do I connect to what so that I can see the on-screen setup display on my Hitachi C36WF810N? I have a Denon AVC-A1SE and I am not sure. The manual sucks.
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,746
    +2,719
    On the back of the Amp there should be some outputs ( both phone and S-Video ) labeled MONITOR OUTPUT.
    Connect one of these to your TV, and then select this input on your TV
  3. rnjones
    rnjones
    If its like the Denon AVC-A11SR the On screen Display (OSD) will only work out of the composite phone monitor output not the S-video output.
    Your TV may have a composite video input under a flap at the front. Usually a yellow socket. Alternativly if you have a spare scart get a Scart to Phono converter and connect the video phono to the monitor out socket on the back of the amp.
    Rog
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The Denon's have an intelligent OSD system. Such that if you have an s-video source connected to the amp it will only output the OSD through the s-video monitor output. If no s-video is present then it will output through composite only.
  5. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Your correct Retro.The avc-a11sr is the same.I my osd going through an s-vid lead to my tv.
    Regards
  6. Epoman
    Epoman
    Jan 3, 2002
    3,128
    71
    On my PC
    +85
    Agree with Retro. 3802 works with S-video also.
  7. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    With nothing connected to the amp i get OSD through S-Video and Composite MONITOR 1 OUT.
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    That would IMHO not be smart but rather stupid (ok, let's say "limited") ...
