Seeing as Yamada sponsor this section...
Discussion in 'Blu-ray & DVD Players & Recorders' started by micol, Dec 5, 2004.
  1. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    I thought I would just say that I am very impressed with the Yamada 6600 player I have. It plays just about every kind of disk you can throw at it, especially DivX & XviD (the reason I bought one). Picture quality is very good and at about £60-70 quid you can't go wrong!
  2. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    yes, except that all the problems with this model that they promised would be fixed via updates for the software never appeared. instead they put all the fixes in the new 6700 model. so if you don't mind butyng a new divx dvd player every 6 months, then you should be ok. :devil:
  3. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Really! Mind you, I have not really had any problems playing Mpeg-4 movies etc. Any that have not worked (2 or 3 so far) I just convert to DVD and watch them that way. For the money, I'm very satisfied. If the player was say £200, then yes, I would be [word removed] off.
  4. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    I too was going to buy this player until i found out it didn't have component output and also after reading a review (what hifi/cinema or something like that) about how poor the sound was is the sound as bad as they made out?
  5. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    Don't forget the new Yamada has just come out - The 6700. Available from ebuyer for £50.
    I've ordered 2, but ebuyer sent me 2 Umax/Yamada 4600 scanners instead. doh!
    It supports ogg, and embedded subtitles thingies?! Basically a 6600 with more memory (RAM I think)
    Check out http://www.my-yamada.co.uk/ for more info.
  6. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    The 6600 does not have component. If you want this then the Pioneer 475A is a very good buy! It is a DivX player, has progressive scan and also plays DVD-Audio & SACD. You can get one for about £120
