SecondiPod to single PC
Discussion in 'Headphones, Earphones & Portable Music' started by masher, Jun 20, 2005.
Tags:
  1. masher
    masher
    how can I get my second iPod to be seen on the PC. Asks to load software again, and this will unload original software. Will I lose all details of first iPod :confused:
    Thanks.
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    This is something I’m quite keen to know too!
  3. HMHB
    HMHB
    Nov 11, 2001
    26,453
    Nottinghamshire
    +5,075
    The normal solution to this is to create a different user in XP or 2000 and log on to that one for the 2nd iPod. You should be able to load iTunes on to that account and have separate sets of music for each one.
  4. mick's cat
    mick's cat
    Alothough multiple users is the complete option it may not be necessary.
    On MacOS, for example, if you plug a second (or subsequent) iPod in, iTunes asks if you want to link the iPod to the iTunes Library. All you do is click No, then the iPod comes up as a usable iPod in the Source list within iTunes. Thereafter, you can manually drag music to the iPod icon. The first iPod is still the main one that links automatically.
    I don't know whether this is the same on Windows, as I've never used an iPod on my PC, but my guess is that it could well be.
