Secondary display on 9800 Pro
Discussion in 'Microsoft Windows' started by pcpaz, Jun 30, 2005.
  1. pcpaz
    pcpaz
    I recently installed a Sapphire Radeon 9800 Pro and is connected via svideo to my 29” Sony TV. The problem I am having it enabling the secondary display. Although in the Catalyst Control Center it shows that there is a TV connected to the card, I cannot enable the secondary display. I can select on the Display number 2 and right click and select enable, but when I click on apply button the display reverts back to ‘Not Active’. I am using the drivers that came with the card, should I use the latest Catalyst MCE drivers available from ATI? This is really frustration as previously I had a Radeon 9200SE which was setup for dual display on monitor and TV without any problems.
    Any help would be great before I destroy my PC.!!!
  2. DaveP
    DaveP
    The latest drivers are usually a good place to start. The latest CCC has better support for TV connections IIRC.
    Be sure to get the MCE drivers (although I believe they are unified now, but there is still a seperate download area for MCE)
    Dave
