Second zone format sky+
Discussion in 'Sky Digital TV Forum' started by philthyanimal, Nov 8, 2004.
  1. philthyanimal
    philthyanimal
    There are 2 screen format options in picture options, What are these for. thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    If you use a TVlink system to feed the RF2 output to a second location it allows the SKY+ to automatically alter the picture ratio to suit the display, the option is activated via the remote control used. Useful for those with a widescreen telly hooked up via scart and a 4:3 telly via RF.
  3. philthyanimal
    philthyanimal
    so it doesn't affect the second scart, as thats how i send my sky upstairs via philips digisender.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Nope, it only works via the RF2 tvlink system.
