Second Television but no socket
Discussion in 'Freeview & YouView' started by heliboymal, Jan 31, 2009.
  1. heliboymal
    heliboymal
    Jun 19, 2008
    30
    Hopefully the informed can help me here. I am in the military and as a result move every couple of years to various styles of house etc. I am currently in a house with 1 TV socket, in the lounge but we are keen to get a TV in the bedroom. Are there any options out there that will negate drilling in walls, etc. I am keen to put down a small footprint but if the only option is to get a second aeiral slot then might have to bite the bullet. Currently have loft aerial that goes to a Humax 9200 box in my lounge for info. Any pointers appreciated. Thank you
    Mal
  2. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  3. heliboymal
    heliboymal
    Jun 19, 2008
    30
    Thanks very much for your speedy reply. A couple of supplementary questions if I may?
    The Digi sender sounds like a good solution but I have a Wireless LAN and am concerned about interference etc; should I be or does it work fairly well in modern digital homes?
    If I were to get a second TV Point in the bedroom I take it I would need a splitter in the system somewhere and as it is a loft and not a roof antenna then are there power issues? Also is this expensive to do?
    Thanks again
    Mal
  4. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
