Second remote sender on Sky+
Discussion in 'Sky Digital TV Forum' started by MrMaxP, Sep 27, 2005.
  1. MrMaxP
    MrMaxP
    Jun 3, 2005
    15
    Hi all,
    I've got the standard remote sender attached to the 2nd RF out on my Sky+. If i split the arial to go to 2 TV's can i....
    A) Put a second sender on the second TV and they will both work fine on the 1 split cable
    B) If i cant will it blow up my second TV as there is a voltage going down that RF cable?
    Anyone got any experience with this?
    Stu
  2. MrMaxP
    MrMaxP
    Jun 3, 2005
    15
    I've got 2 on a cable splitter in diff rooms. As long as you dont try and change channels on both at the same time it works fine.
